Magneto Maintenance
Magneto Maintenance
Postby Skygeezer » Mon Jan 18, 2016 11:55 pm
My Sonex has a Great Plains 2180 cc engine serial number 071403-0113FDIC. The engine has about 150 hours. Lately during preflight run-up the magneto has been showing about 150 RPM drop when switched from "Both" to "Mag". Up till now, the drop has been 50 RPM or less. I would like to check the points and their gap, but I can't find any information on this in my Engine Assembly Manual. On the page for Scheduled Maintenance, at Magneto it says "See magneto section", but my manual does not have a magneto section.
I would appreciate any information anyone can provide on magneto maintenance and point gap.
Skygeezer
Skygeezer
Re: Magneto Maintenance
Postby Mike53 » Tue Jan 19, 2016 8:18 am
Mike
Antoine de Saint-Exupery
Mike53
Postby mooneybum » Tue Jan 19, 2016 5:48 pm
I would think you should check the timing between the two ignition systems first I have the almost same engine with over
400 hours on it and the mag shows no problems.
mooneybum
Postby Skygeezer » Thu Jan 21, 2016 6:25 pm
Thank you very much. It was a major help to get access to the maintenance manual. From what I've read so far, it does sound like timing is the first thing to check.
Skygeezer
Return to Sonex
Users browsing this forum: Google Adsense [Bot] and 64 guests
