iLevil Sport
iLevil Sport
Postby Sonex1517 » Thu May 15, 2014 7:27 pm
Does anyone have hands-on experience with an iLevil sport?
I am looking at one to use with an iPad mini.
Thanks!
Robbie
Re: iLevil Sport
Postby SonexN76ET » Fri May 16, 2014 2:51 pm
I have an iLevil AW. It is the iLevel with the pitot static ports, ADHRS attitude sensors, GPS and ADS-B. I use it with an iPad and use the iLevil HUD utility and WingXPro. I really like the iLevil AW. But, I am a little disappointed with WingXPro (a completely separate company) as they advertise that it works with pitot static inputs but WingXPro keeps the barometric setting at 29.92 and you have to adjust the altitude versus entering the barometric pressure (i.e. manually change your elevation from 5000 to 5500 based on knowing your altitude from another source (a separate altimeter or GPS or the iLevil HUD utility)). iLevil said they are trying to convince WingXPro to add the ability to change the barometric pressure. I have also contacted WingXPro but got into an argument with them when they said to just set the altitude to field elevation when you take off. I told them how can you be in compliance with ATC when they give you a barometric pressure and then assign you an altitude. They said just use your FAA approved altimeter and that their product is not supposed to be a primary source for navigation that it is only for reference, etc. So, I ended up installing a 2 1/4 inch altimeter (Another $350 I had hoped to have avoided.
If I had to do it all over again, I would get the GRT Mini EFIS for $995 and just use the iPad for a map and probably go with the Jeppessen VFR only GPS software.
Sarasota, Florida
SonexN76ET
Re: iLevil Sport
Postby snx590 » Fri May 16, 2014 3:05 pm
Have you decided on the iLevil Robbie?
If not and you use Foreflight, for $100 more I would highly recommend the Stratus 2, which also would give you ADS-B weather.
I had the chance to wring it out to Sun-n-Fun and back last month (C172, not my Sonex). The AHRS was flawless, GPS and ADS-B reception rock solid. The only issue was some overheating on the way down when placed on top of the panel. Picked up the RAM suction mount for it and when stuck to the side window on the way back, no more heat issues.
Terry
Sonex #590, J3300
snx590
Re: iLevil Sport
Postby fastj22 » Fri May 16, 2014 4:48 pm
I recently went with the Dual 170 primarily due to the price, $550, but also it works with more than just one iPad app. The Garmin 3DL works only with the Garmin app, the Stratus only with Foreflight. The new AOPA app is really good, so I went that route.
I've only had one flight with it and wasn't really impressed with the ADS-B weather. I only received one METAR from an airport on the other side of town after flying more than 55 minutes. And I got that METAR while taxiing for takeoff. I'll fly some more this weekend with it and see if that's normal or something is wrong. I did throw it in my car for my commute and it got a different METAR from across the state. I do know that you shouldn't get great reception on the ground, but I was curious.
iLevil Sport
Postby Sonex1517 » Fri May 16, 2014 6:40 pm
Thanks for the replies everyone!
I am going with the iLevil SW. A very good friend of mine was selling his and I got a great deal. Too good to pass up.
I needed something to have when I get into phase one about a year down the road, and had been looking at various solutions. Combined with my iPad mini this looks like a really useful tool.
Once I actually have time on it I plan to write a full detailed review for the Foundation newsletter...
Blue skies
Chicagoland
N1517S reserved
iLevil Sport
Postby Sonex1517 » Fri May 16, 2014 8:38 pm
Figured I would add this - I have no dog in the fight, and no financial interests here:
ILevil SW (from their website http://www.aviation.levil.com/ilevil-sw-1.html)
This portable tool combines the latest in GPS, AHRS and ADS-B technology to bring pilots an affordable backup solution that is both Android and iOS compatible. The internal GPS and AHRS provides all the navigation information you need to turn your tablet into a real glass panel. The embedded ADS-B receiver allows you to monitor weather radar, METARS, etc in addition to traffic information all at your fingertips AND without any subscription.
I originally titled the post incorrectly. I am getting the iLevil SW, not the sport.
Chicagoland
N1517S reserved
