No EGT or CHT Readings: MGL MX1 with RDAC XF MAP
Postby pfhoeycfi » Sun Oct 16, 2022 2:31 pm
HI,
I have 4 EGT and 4 CHT and they all remain about 60 deg F even when the engine is running. Oil temp, oil pressure, fuel level, RPM and MP readings seem good. I checked my connections, they seem to be ok. My setup appears correct. I would appreciate any suggestions.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: No EGT or CHT Readings: MGL MX1 with RDAC XF MAP
Postby GordonTurner » Sun Oct 16, 2022 4:43 pm
No personal knowledge of this system, but perhaps you can double-check you have correctly programmed the RDAC. For example, K or J type sensors.
Gordon
Postby BRS » Sun Oct 16, 2022 6:43 pm
Hi Peter,
I have a MX1. Attached is what my TC Channel page looks like. Also check to make sure polarity on the probs to the RDAC is correct. As I recall Yellow is positive (not red). I had made that mistake.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby BRS » Sun Oct 16, 2022 6:46 pm
... Also, go to
MENU/System diagnostics/RDAC 1 diagnostics
This will give you an idea of what inputs have valid connections (raw data)
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby GraemeSmith » Sun Oct 16, 2022 8:51 pm
SNAP! I just switched my RDAC for one of these on Saturday. To replace an early model RDAC. I can tell you that your polarities are correct (yellow positive) and the dip switches for RDAC SEL B and A are correct if this is your RDAC 1 (which your setup screen says it is).
The one thing it took me a bit of figuring out to get right was the EGT and CHT lead positions. The example in the manual is NOT intuitive. 1 thru 4 must be EGT's and 5 thru 8 CHT's if your EFIS "autosenses". i.e.- EGT's FIRST. Your setup screen shows that you can select. Your setup screen shows 4 EGT's followed by 4CHT's - so the question then is:
Are you sure you have the EGT's in 1 thru 4 and the CHT's in 5 thru 8. Cuz it looks like you MIGHT have them swapped and have the CHT's in 1 thru 4.
And try J type instead of K.
NOT saying I am right - but from what I see in your pics and just learned - it is what I would be checking/trying first.
Postby BRS » Sun Oct 16, 2022 9:09 pm
GraemeSmith wrote:SNAP!
Graeme,
Did you realize those pics are mine and not Peters?
-Brock
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby pfhoeycfi » Mon Oct 17, 2022 6:32 am
BRS wrote:... Also, go to
My wiring is the same as your pic. My sw setups are the same except that my rpm filters are off. I should have mentioned my raw data for the temp inputs are all zero which can't be good. Perhaps I'm shorting across one of the inputs. I'll need to double check that.
Appreciate the pics!
Peter Hoey
pfhoeycfi
Postby GraemeSmith » Mon Oct 17, 2022 6:39 am
Graeme,
-Brock
Ha Ha! No. Blame it on a long day...
Peter - make yours look like Brock's!! :-)
