MGL Enigma RDAC and CUBE Fuel Flow Sender
Postby GraemeSmith » Tue Apr 20, 2021 1:00 pm
Using an EI red/gold cube (wiring is the same) fuel flow unit. Trying to match the wiring to the different installation manuals.
RDAC and Cube both call RED wire as the +5v.
RDAC calls BRAID as the ground. Cube BLACK(?) wire ?
RDAC calls BLUE as the signal. Cube White (?) wire
Anyone find the need for a pull up resistor to get the RDAC to see the cube and if you did - a value?
TIA
