bvolcko38 wrote:(3) The manufacturer of the aircraft on which the transponder to be tested is installed, if the transponder was installed by that manufacturer.
That's me!
lakespookie wrote:This is one of those things that unless your are an A&P/Avionics shop with the equipment or have someone that fits that bill in your EAA chapter you are probably going to have to shell out to one of those guys. Based on my elementary interpretation of the legaleaze can you do the test sure. Are you equipped to do the test IDK but I suspect not.
