RPM readings Wrong and erratic on MGL E1 Help please
Posted: Sat Nov 30, 2019 10:22 am
I recently purchased a used Waiex with Jab 3300 engine. In the panel is a pair of MGL instruments, the E1 for engine monitoring and the Flight 2 for airspeed and altitude etc...
Honestly I really am not a fan. If I had built this plane I would have probably used a EIS for the engine and something different for flight monitoring, but this is what the plane came with...
The RPM readings are for sure wrong. Erratic as well. at low rpms I believe the gauge may be right, but in flight I see readings as high as mid to upper 4000 rpms and even at a set engine speed and airspeed the gauge just shows readings constantly going up and down.
I do not know what to check.
I also do not know if the Jabiru engines alternator is working. There is a voltage reading in one of the MGL gauges and also there is a stand alone instrument, a GT-50 that displays voltage. in flight the voltage displayed on the MGL was under 12 volts, and the GT-50 was showing the same voltage in flight as was shown on the ground with everything shut down and switched off. It is possible there could be a problem with the alternator or voltage regulator causing the RPMS to be off as well?
