uAvionix ADSB out - "BaroAlt" Fail
Postby GraemeSmith » Fri Aug 02, 2019 8:05 am
For those that might follow.
Specific to my experience with the echoUAT unit but apparently applies to other uAvionix units:
I installed and flew my test flight. The FAA Performance Report report came back as perfect except for the "BaroAlt" parameter which was an 85% fail rate.
A little forum digging and talking to uAvoinix.
A suggested fix is:
In the software on the screen of your phone or tablet where you are configuring the unit.
Connect to your uAvionix unit.
Tap "Configuration"
Tap the uAvionix logo at the top of the screen with two spaced fingers.
Scroll down to a new menu that appears below the UPDATE button.
Set - SDA to 2
Set Transponder threshold:
The default value is 1600. Try 1400.
Tap UPDATE ADVANCED
Perform a test flight.
"BaroAlt" should have improved. If it is still not a "pass" lower the Transponder Threshold setting in steps of 100, performing a test flight each time till you get a satisfactory result. Do not lower the setting below 1000. If 1000 doesn't get you a satisfactory result - back to uAvionix.
Re: uAvionix ADSB out - "BaroAlt" Fail
Postby planeolbob » Wed Nov 06, 2019 11:44 pm
I flew my performance flight today and had the same failure. I will try ASAP using your fix. I hope it works. Here is a link to my Flickr site showing the install
https://www.flickr.com/photos/planeolbo ... 1677563048
Bob (flying back and froth) Mika
planeolbob
Postby planeolbob » Thu Nov 07, 2019 4:06 pm
Hi Everyone,
I reset the transponder threshold to 1400 and SDA to 2. I then flew and got my clean report back from the FAA. Here is a copy of the data on my Flickr site.
Bob (happy and legal) Mika
planeolbob
Postby GraemeSmith » Thu Nov 07, 2019 6:32 pm
Awesome!
Re: uAvionix ADSB out - Revised
Postby planeolbob » Fri Mar 20, 2020 5:52 pm
Hi Everyone,
Well, It's always something. I finally have all the stuff fixed on my airplane and the weather may break soon but we are having a bit of a problem with " Other Things".
So I decided to revise my ADS-B system. The following photos show what I did.
ForeFlight did not give me the kind of navigation I was used to with my old GPS. So what I did was to load ForeFlight into my iPhone 5s and move the little bracket over next to the GPS. This gives me a display the confirms the ADS-B is working, General location of weather without blocking any outside visibility. Since my power has two slots I can still have the Ipad mini for cross country trips. I also replaced my circuit breaker to one I can pull in case I need to shut down my ADS-B out when I go to Oshkosh (cross our fingers).
Anyway, I hope to fly in a few days to see how all this works.
Stay Healthy,
Stay Calm,
Stay Safe.
Blue Skies,
Bob Mika
N178KT
planeolbob
Postby WesRagle » Fri Mar 20, 2020 9:53 pm
Hi Bob,
Off topic I know, but what was the problem with your EGTs?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby planeolbob » Sat Mar 21, 2020 12:08 am
I damaged them while removing them during maintenance
planeolbob
planeolbob
Postby WesRagle » Sat Mar 21, 2020 9:31 am
Thanks.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
