by Rick524 » Tue Dec 11, 2012 7:24 pm
Anyone have any experience / tips on calibrating an Enigma shunt?
Thanks!
Rick
Sonex524
Rick524
by normansemaj » Thu Jun 13, 2013 6:25 am
If you want to know anything about these then you should visit
3d prototyping as I also gain many information from these related to Enigma/IOX/shunt calibration.
normansemaj
by Mike53 » Thu Jun 13, 2013 7:26 am
Rick524 wrote:Anyone have any experience / tips on calibrating an Enigma shunt?
Thanks!
Rick
Sonex524
Hi Rick.
Have you tried the MGL forum.There will likely be more knowledge base over there.
http://www.mglavionicsusers.org/Cheers,
Antoine de Saint-Exupery
Mike53
by Rick524 » Fri Jun 14, 2013 4:20 pm
Hi Mike, I've searched the MGL board and see others have had similar problems. Bob Meyers was
a big help to me. He didn't have any problems with his setup, so I know it can be done. I saw a post
somewhere that its a software problem. You get one shot at the setup and if you mess up it wont
calibrate again. There is a sequence of keystrokes and resets to go thru to get it calibrated....I saved the
message somewhere. I moved on to other things and will try again when I'm ready.
Rick
Sonex 524
Rick524
