Mixture control knob
Postby Darick » Mon Jun 13, 2016 9:59 am
...just wondering about the quality of this mixture control knob from AIrcraft Spruce...
https://www.aircraftspruce.com/catalog/ ... shctrl.php
It's small, low cost and locks/unlocks with a button, available in 5 or 8 foot lengths, can be shortened.
Any other recommendations?
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Mixture control knob
Postby wlarson861 » Mon Jun 13, 2016 11:59 am
The one you want is the a-700. The one you show is just a push pull . You will want the locking type. You may also consider a vernier type for more accurate setting as the mixture is kind of sensitive.
Bill Larson
N861SX
wlarson861
Postby fastj22 » Mon Jun 13, 2016 1:50 pm
I've flown with both the push/pull and the vernier. I like the fine tuning of the vernier much better.
Postby GordonTurner » Mon Jun 13, 2016 7:08 pm
I second John's opinion. Vernier for mixture is worth considering.
Gordon
Postby mike.smith » Mon Jun 13, 2016 7:10 pm
I have a push/pull and it works fine. It does tend to wander "out" a quarter of an inch or so at times if it's starting from the full rich (in) position.
