fastj22 wrote:I have a Belite fuel sender (measures fuel weight) and used it with my MGL xtreme. The problem I found was the Belite produces a voltage of 0 to 5 V. The MGL likes 0 to 4V. So when full, the MGL displays ERROR. Once the level goes down below 4V, it reads fine. I also use the MGL calculated fuel level and the Red Cube flow transducer. The levels are very close in flight once I get below the 4V level.
gammaxy wrote:Thanks for the update. I like the idea of the belite fuel level sender. If I ever have problems with my capacitive sender, I might give it a try. It's interesting that it is effected by engine RPMs. Do you have any way of isolating whether it is electrical noise or mechanical? I suspect it is likely to be some ripple from the alternator, but wonder if it could also be caused by mechanical vibration.
