Where to place the MGL SP-6 Compass and SP-7 AHRS?
Postby Sonex1462 » Wed Dec 10, 2014 11:26 pm
I was wondering where people are installing their MGL SP-6 Compass and SP-7 AHRS units.
I am installing dual XTreme EFISs.
I was thinking of putting the SP-7 AHRS under the seat on the channel supports in the middle.
And the SP-6 Compass on the cross tie channel at the rear of the baggage area.
Any Comments?
John Stewart
Sonex 1462
John Stewart
Sonex 1462
Kit, Aerovee, Tri Gear, ST Controls
Website: http://stewartaircraft.net
Sonex1462
Re: Where to place the MGL SP-6 Compass and SP-7 AHRS?
Postby Fastcapy » Thu Dec 11, 2014 12:32 am
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby gammaxy » Thu Dec 11, 2014 12:43 am
I'm pretty sure the elevator pushrod is supposed to go exactly where you have the SP-7 (at least in the lowered-seat Sonex).
I like Fastcapy's locations. I would be careful about the proximity to the steel pushrod and the magnetometer, but it sounds like it's not an issue for him, so that's what I'd try. A little simpler than making a mount in the baggage area that could potentially interfere with a baggage sling.
Postby Fastcapy » Thu Dec 11, 2014 1:00 am
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby Sonex1462 » Thu Dec 11, 2014 11:09 am
I don't know if I have the newest firmware update. How can I check?
John Stewart
Sonex 1462
Sonex1462
Postby mike.smith » Thu Dec 11, 2014 7:23 pm
I put mine pretty much where you did (other than my magnetometer hangs out over the bay behind the luggage area). For the magnetometer I tested locations with a wet compass including under the seat, but all the steel for the controls were making the compass needle turn, so I put it back where you did, installed with brass screws, and it seems to work perfectly.
Postby fastj22 » Thu Dec 11, 2014 9:12 pm
Sonex1462 wrote:I don't know if I have the newest firmware update. How can I check?
When did you get it?
The big firmware update came last year which radically changed the way it calibrates. I gave mine to MGL at AirVenture 2013 to update. So if you received it before July of 2013, you probably need the update. You can probably do it yourself but you will need to build a cable to do it.
Postby Sonex1462 » Thu Dec 11, 2014 9:45 pm
I got mine the first part of this year (2014). So I think I have the newer firmware. The documentation that came with it references the new calibration instructions as of July 2013.
Thanks for the info.
John Stewart
Sonex 1462
Sonex1462
Postby Gripdana » Fri Dec 12, 2014 10:35 am
I live near MGL and talked to Matt when I picked up my avionics. He told me to make sure to use a simple backpacking compass to check for magnetic interference and to make sure I use a solid mount. He also said they have had good results eliminating hi frequency vibrations using velcro to attach the SP-6 and SP-7 to their mount. Here is what I did.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Postby Sonex1462 » Fri Dec 12, 2014 10:38 pm
Thanks to everyone for sharing.
John Stewart
Sonex 1462
Sonex1462
Users browsing this forum: Bing [Bot] and 13 guests
