Coolant temperature sender setup
Postby Major36 » Thu Jul 10, 2014 5:05 pm
I have an Enigma EFIS with a RDAC.
I am installing a MGL coolant temperature sender.
1. What port do I hook the wires up to the RDAC? I don't have a port labeled "coolant" as some do.
2. How do I program the EFIS for the new sender?
3. I have a gauge on the EFIS labeled "FLOW" that is not in use. How do I remove this?
I have submitted an email to MGL with no response.
Waiex
Major36
Re: Coolant temperature sender setup
Postby fastj22 » Thu Jul 10, 2014 8:14 pm
I assume you have an RDAC XB model. The XF has a COOL connector.
1) You would connect it to either the CHT1/WT/AUX3 or CHT2/Carb Ice/AUX4. The WT is water temp. I installed a second OAT to the AUX3 post and monitor cowl temperature with it.
2) Each sender has a type you will select in the EFIS configuration. There should be a menu of available sender types to choose from.
3) I don't have an Enigma, but I assume its similar to my xTreme. On the fuel setup menu, go into FLOW and remove the sender type (set to none). That should remove it from the screen.
Go to this forum for more help. they sometimes are quicker than asking MGL directly for help.
http://www.mglavionicsusers.org/forum/index.php
What engine are you installing that is water cooled? Jab with LCH?
Postby Major36 » Thu Jul 10, 2014 8:48 pm
You guessed correct. Jabiru 3300 1098 125 hours. Installation almost complete. Probably start it up this weekend for some tests.
Waiex
Major36
Postby fastj22 » Thu Jul 10, 2014 9:19 pm
Major36 wrote:You guessed correct. Jabiru 3300 1098 125 hours. Installation almost complete. Probably start it up this weekend for some tests.
Waiex
Please report your results. I'd love to see how you mounted the radiator and which one you used. Last year I was a mouse click from being the first Sonex LCH. Still might go that route. My cooling is much better after I opened the cowl bottom up a lot, but I'd still like to climb without worrying about cooking the heads.
Postby Major36 » Fri Jul 11, 2014 7:24 am
Send me a pm at major4567@yahoo.com. I have tons of pics and can fill you in on the progress. If anyone else would like to follow along please feel free to do the same. I have several people following the conversion.
Major36
Postby ScottM-Sonex1629 » Fri Jul 11, 2014 8:40 am
Steve:
I really think a summarized report after your done posted on this forum or Sonex Foundation would be awesome for documenting your work and research!
Plus you could include all of those sexy pictures of the coolant manifold you've been sending us pictures of!!!!
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
