ELT Antenna Placement
Re: ELT Antenna Placement
Postby N190YX » Sat Jul 03, 2021 11:22 am
Regarding the placement of the com antenna, I contend the bottom of the fuselage is the ideal location because 1) aerodynamically, the air is moving faster on top versus on the bottom of the fuselage, so less drag; 2) aesthetically, fewer antennas on top of the fuselage looks better; 3) no ground plane issues either way; 4) ground communications work fine with a bottom mounted com antenna, the landing gear does not interfere with transmission or reception, I have had one on the bottom of my certified airplane for decades and have never, repeat, never had a communications problem during ground operations at my control towered home base or during ground operations at any airport anywhere. Also works fine in the air. I highly recommend placement of com antennas on the bottom of the fuselage. 45 degree or 90 degree bent antennas, attaching photos of a couple samples from Aircraft Spruce. Mine is a 90 degree bent antenna.
Comant CI E22.jpg (6.58 KiB) Viewed 1710 times
Comant CI-121.jpg (5.81 KiB) Viewed 1710 times
N190YX
Postby Scott Todd » Sat Jul 03, 2021 11:26 am
FWIW, faster moving air is more drag....Its actually a function of the velocity squared.
Scott Todd
Postby builderflyer » Mon Jul 05, 2021 9:46 am
N190YX wrote:Regarding the placement of the com antenna, I contend the bottom of the fuselage is the ideal location Mine is a 90 degree bent antenna.
I absolutely agree with the above conclusion despite what the naysayers may conclude. My Sonex has had a belly antenna since day one and it was based on a towered airport for its first ten years without a hint of ground communications issues, no matter where located on the airport. And, in the air it may even be more effective than a top mounted antenna since there is a lot less aluminum in the way between the belly antenna and a receiving ground station. All the antenna theory out there can't be used to argue against success.
Art,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
