pilotyoung wrote:I just put a new all digital panel in my Onex. I have been flying an RV-12 with an all digital panel for 4 1/2 years. My friends sometimes ask me what I am going to do if the power goes out. I tell them, Look out the window, fly the airplane, and land it somewhere, hopefully on an airport.
When I used to teach students, before I would let them solo, I would cover up the six pack of instruments and tell them to fly the pattern and land. The first reaction was I can't, I don't have an airspeed indicator or an altimeter. I told them fly the same attitude and power settings you have been flying. You know those, fly them. I never had one crash.
So I am totally comfortable flying an all electric airplane. If you are not, get with a CFI and have him turn off the digital instruments just before you enter the pattern and land. Do it several times and it will give you confidence. If you are still not comfortable, add an airspeed indicator.
Onex107 wrote:My AOA/ASI reads from 70 mph to 0 with stall speed indicated at the beginning of the red area. Green, yellow, and red aeras on a differential pressure gauge. The probe is non-electric and home made from internet plans. A friend has made 3D drawings of the probe and makes them on a 3D printer. It even makes the pipe tap in the tubing connections. I use the AOA every time I land. It's in my line of sight on the left top of the panel. If you practice tight 180 degree turns you will be surprised how close you come to stall in a 2G turn. It's the only instrument necessary , and will help you make better landings. Wouldn't fly without one. Total cost about $75.00
