Panel space
Panel space
Postby Aussiecat » Thu Mar 25, 2021 2:33 pm
Hello,
I am curious, as I didn't see anything on the sonex site, how much space is behind the panel on a B model before you butt up against the tank? with modern flat panel EFIS's, most of the other equipment is remote mounted. Are most builders making and equipment shelf behind the panel to mount the extra hardware? I would be considering a Dynon system.
Tim
Aussiecat
Re: Panel space
Postby Spaceman » Thu Mar 25, 2021 2:39 pm
The plans say 11 15/32" 'approximately maximum instrument depth.'
You could make a shelf that mounts to the underside of the upper longerons to mount some stuff... I thought about doing that but I ended up fitting everything I needed on the aft side of the firewall and behind the seat!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Return to Panel
