Waiex #142's Panel - A Dual Dynon Skyview System for a Sonex
Posted: Thu Feb 14, 2013 4:38 am
I am going to use this thread to document the construction of a custom panel for my Waiex. Up to this point i have been pretty quiet about it, because in the back of my mind i had the sneaking suspicion that i had spend a bunch of money on some avionics that would not fit into the airplane i was building (and that would be really embarrassing). But i am at the point where i have convinced myself that this will work.. so ill start spilling the beans.
Here is my list of stuff that i need to figure out how to fit:
Dual Dynon Skyview 7" screens
Garmin SL30 Nav/Com
PS Engineering PM3000 intercom
Kannad Integra ELT (Remote Head)
Ignition (keyed) switch
Master switch
Standard Aeroconversions Trim Knob
qty (2) 2" Steinair eyeball fresh air vents
Avionics switch
Position, Strobe, and Landing/taxi light switches
Autopilot switch
Smoke System Enable switch (why the heck not)
Zero breakers or fuses, because i am using a Vertical Power solid state breaker system.
Its really not that much when you think about it.. i have seen Sonex panels cluttered with way more stuff than that before. The problem is that the two Dynon screens take up so much space, there is hardly any room left for anything else. One really great aspect of the Skyview system, is that it uses a remotely mounted transponder, so that does not have to take up any precious panel real-estate. I can also justify not having any steam gage backups, because the two screens (each with their own independent 30 min battery) are a completely redundant source of PFD, Engine Monitor, and Navigational information. The issue at hand, is that there is no way that two dynon screens will fit within the stock Sonex panel.. so i will have to get creative....
Ok, so here is the basic concept. I like the idea of a composite panel, and i picked up some really interesting/artistic colored carbon/glass twill weave (that just so happens to contain my favorite color) to make it with. All of the faces are flat planes, so it should be reasonably easy to make a tool to create my dream panel. I started off by modeling everything in SolidWorks, just to check to see if i hadn't gone insane already:
I know that some people had made 1" and even 1.5" lower cross members below their panels to fit extra switches and breakers, so if i just extend the panel slightly more than stock (about .25" or so) and then extend the center area by 1.6" more, i was able to fit the SL30 radio centered beneath the two screens. I like the looks of it, too!
I decided that i must first make a real-life mock up of the panel, because if i went straight to a tool and then a composite panel, there is no way the first try would come out anything close to fitting properly. I chose 3/4" MDF board to make the mock up.
And i actually made three mock ups, each slightly different (and it took three try to get a fit that i liked too).
Here is the lucky winner, with two life-size dynon cardboard screens on it to prove that they fit!
This mock up was created by first cutting the top edge to a 30 degree angle on the table saw:
And then a compound miter of exactly 57.25 degrees (swing) by 24 degrees (tilt) for the sides. (DISCLAIMER: i would be willing to bet that if you copied my technique, your numbers would be slightly different)
Then, i made a 1/4" trim piece to represent the perimeter of the SL30 radio. When the radio is installed, and parallel with the face of the panel (at 30 degrees tilt, which is the stock tilt) it *just* clears the bottom of the fuel tank. Without this tilt, the radio is long enough to interfere with the tank, but i got lucky and it looks like it will work and still be able to be flush fit.
And here is my first test fit with everything in. Believe it or not, there is still just about the same amount of clearance between the corner of the radio and the stick as there is against the trim knob in the factory default location if the stick were pushed over to the left. I would call this success with the initial concept fit!
Thats all for now, next up: creating a mold tool for the panel.
Garmin SL30 Nav/Com
Master switch
Avionics switch
Autopilot switch
