1534 Panel update
1534 Panel update
Postby Gripdana » Sat Aug 23, 2014 9:39 am
Here are updated photos of my panel. For the test switch I installed a DPDT relay to these the warning lights. The wiring is done except for the items in the plane (transponder, lights, fuel probe. You can view photos on flicker at https://www.flickr.com/photos/90889513@N04/
or my builders page at http://websites.expercraft.com/gripdana ... g_id=79328
Sorry the board won't let me post any more photos.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Re: 1534 Panel update
Postby Gripdana » Sun Aug 24, 2014 12:44 am
I test fit the panel today. It fit well. I am worried about the cross channel rubbing on the wires so I will put a piece of rubber hose on the edge. I also got the compass installed.
Dana Baker
Scratch Built
Gripdana
1534 Panel update
Postby Sonex1517 » Sun Aug 24, 2014 9:19 am
Looks great Dana!
Chicagoland
N1517S reserved
Postby MichaelFarley56 » Sun Aug 24, 2014 1:44 pm
Great job on the panel Dana! I sure wish that MGL Xtreme was available when I bought my stuff. I love how small yet useful and capable it is! You'll be happy you went with the (cigarette lighter) power plug for charging electronics!
Are you going to install air vents in the front windshield? Side mounted throttle and mixture?
Thanks for sharing the pics...looks great!
Postby Gripdana » Sun Aug 24, 2014 2:00 pm
I mounted the RV vents on both sides just forward of the panel. I am going with the Sonex ST center throttle/mixture per plans that will mount to an angle that will mount center and have the head phone jacks on each side of the quadrant.
Dana Baker
Scratch Built
Gripdana
Postby wlarson861 » Thu Nov 27, 2014 3:11 am
I see you have the plans type left hand flap and brake bracket installed. I first flew mine with center throttle and mixture but left side flap and brake. This created a bit of a hand dance in the pattern when adjusting throttle for landing and then switching hands to deploy flaps then back to control throttle. I thought it would be ok but I did get a bit of a rebuke from the factory. One of the first changes I made was to incorporate the rest of the sport trainer mod by moving the flap and brake to the center. It wasn't that big of a mod (maybe a short days worth of work) but it does seem to make life easier when your busy on the approach and roll out. I did the center throttle and mixture out of habit. The planes i trained in and owned all had left stick right throttle set ups (C152,Luscombe 8a, C177). My biannual was in a Champ and I never was comfortable with the left hand throttle-right hand stick.
Bill Larson
N861SX
wlarson861
Postby Gripdana » Thu Nov 27, 2014 1:02 pm
Currently I fly left and right seat in C-172's, 182's and Cherokee's getting prepared for my CFI. I am aware of what you are saying. I have sat in and tried it. My thinking is that the cockpit is so small I would not have a problem switching hands or reaching the throttle with my left hand. I was not planing on giving transition training when I set out to build. But when I have finished the build and CFI I will move the flaps and brake to the center.
Dana Baker
Scratch Built
Gripdana
Postby Darick » Sun Nov 30, 2014 6:45 pm
On several of your pictures, I see a black or red thin box, wired in line. One is marked "starter 7A"? Are they in line fuses?
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Gripdana » Sun Nov 30, 2014 7:00 pm
Yes they are inline fuses. I purchased them from B&C. I think the red ones are 12ga. That is what I remember.
Dana Baker
Scratch Built
Gripdana
Return to Panel
