alphapapafoxtrot wrote:I have heard in other posts that some people have had trouble getting autopilot to work with Sonex in general due to low wing loading and being very responsive. I am currently building a Waiex, and I plan to use acro aileron. I wonder if non-acro aileron is more appropriate with autopilot use?
GordonTurner wrote:Sounds like we are planning similar panels. I am going with G3X, GTX375, and MGL V16/N16. I have decided to mount the 375 high in the panel extending over the fuel tank. Everything else has no real depth. The Razor ties in to the system with RS232, the MGL components have their own mini-CAN bus which specifically CANNOT be tied into the Garmin CANBUS.
I have a fairly detailed load analysis put together which I am happy to share. It’s a spreadsheet so you can easily adjust any values you disagree with, or add or subtract items.
Planning is cheap, so keep at it.
Gordon
alphapapafoxtrot wrote:Slightly on a tangent since you mentioned N16 radio. What kind of VOR/NAV/GS antenna are you planning to use?
I have seen cat whisker antenna sticking forward from aft tailcone near ruddervator. Blade antenna looks nice as well.
lakespookie wrote:Thats actually a pretty cool mounting location I am building a trike so i was planning on a belly mount but that install you did in the tail is pretty neat my only concerns would be servicability
