Spaceman wrote:If you kill the engine by shutting all the ignition off, like in the pattern, will it fire right back up when you turn everything back on? Will an Aerovee windmill at pattern airspeed? Honest question, I have no idea!
Rynoth wrote:I was at 80KIAS when I pulled the mixture and 75KIAS when the prop stopped after about 8 seconds. Mixture in, then immediate restart using the starter motor.
WesRagle wrote:When the engine dies quickly pull mixture to idle cut off.
Engage the starter until either the engine fires (the flood is cleared) or 5 seconds passes (the engine wasn't flooded).
If the engine fires advance the mixture to full rich immediately.
If it doesn't fire advance the mixture to full rich and continue cranking.
Wes
Rynoth wrote:I'm not going to flight-test flooding my engine,
