The remaining rocker arms did not exhibit the appearance of arm adjustment in accordance with the kit manufacturer's assembly manual.
The ball bearing on the end of the valve adjuster had seized in place and could not be rotated
gammaxy wrote:This picture from the docket (https://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=59689) shows that the other 3 adjusters don't seem to be adjusted correctly:
mike.smith wrote:Too many shims under the rocker shaft assembly?
rizzz wrote:mike.smith wrote:Too many shims under the rocker shaft assembly?
Or the push rods cut too short, it would be interesting to see the rocker arm positions relative to the valve stem mid-lift.
