Solo seatbelt
Solo seatbelt
Postby thad14433 » Fri Apr 29, 2016 4:09 am
How are the lap belts used for solo center seat flying in the Sonex? Just use the outer belts or has anyone made attach point modifications?
thad14433
Solo seatbelt
Postby caveman370 » Fri Apr 29, 2016 4:32 pm
thad14433 wrote:How are the lap belts used for solo center seat flying in the Sonex? Just use the outer belts or has anyone made attach point modifications?
caveman370
Solo seatbelt
Postby caveman370 » Fri Apr 29, 2016 4:34 pm
I just use the outer belts. Just have to adjust them out and one shoulder harness from each side
caveman370
Re: Solo seatbelt
Postby Darick » Sat Apr 30, 2016 9:41 am
Recently while sitting in my unfinished airplane making flying noises, I tried hooking up the seat belts in the center position (I have the center stick). Using one seat and shoulder belt from either side will work. However, the shoulder belts are just looped around the anchor which of course is bolted to the frame. There is a small amount of stitching that forms the loop and keeps the belt from pulling the whole way through.
Now, if you are only using one half of a shoulder belt assembly, that small amount of stitching is what holds you back. How strong is that stitching? If the force of the crash is enough to rip that stitching, is it an unsurvivable crash anyways?
The stitching is in the shape of a box with an X through it.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Return to Safety and Training
Users browsing this forum: No registered users and 59 guests
