Kai wrote:Still something has to be done with those engines that are cooking their heads and/or are overheating their valves. So I wonder what the Corvair community has done to get on top of this?
Hambone wrote:Thanks to all for the interesting and useful information!
In retrospect, I have only myself to blame for this situation. Knowing now what I didn’t know then (ain’t hindsight grand?), I should have insisted on a leakdown check. The seller apparently didn’t do one when he performed the conditional inspection back in October, claiming that the engine wouldn’t generate full power if there was a compression problem.
Live and learn, they say…
Kai wrote:His concern were the angular brackets (this was of course for the Legacy) in the fuselage front designed to accept the mount: they had never been calculated/tested for more that 200 lbs.
flyguy0609 wrote: In my opinion. the reliability, low cost of maintenance and purchase as well as the extra 5 knots from exchanging the nose wheel for a tail wheel, makes the Corvair engine a good choice.
Kai wrote:Hambone wrote:Thanks to all for the interesting and useful information!
Now I am am confused- what happened to the small dia fuel line in an ear?
You take a 1/4 in clear (or blue) soft flex fuel line of some length. Then you take off the cowling. Then ignition OFF and fuel OFF and throttle to full. Take the dipstick out of its tubing/crankcase hole and stick in the fuel line. Stick the other end in your ear. Tell the owner to pull the prop over a few compression strokes.
If you hear a hissing sound in your ear you know that at least one of the piston rings is leaking. The engine will require an overhaul.
The same procedure with the flex line in the exhaust outlet. If it hisses, one/more of your exhaust valves is/are leaking.
Then the same with the hose in the carby throat: hissing and one/more of you inlet valves is/are leaking.
Of course there are nuances here-especially the piston rings: but surely everybody does at least that before the purchase of a second hand engine??
