gammaxy wrote:Onex107 wrote:In conclusion, I chose the Aerovee for all the good reasons. The only problems I have had were caused by me, made during assembly. Easily corrected. The Hobbs just turned 151.3 hours and I'm looking forward to hundreds more.
In an earlier post you mention losing a cylinder due to a fouled plug. Do you feel like this was a problem you caused during assembly? What do you think the culprit was? I would expect that the big gaps (compared to other aviation engines) and the redundant ignition would make completely losing a cylinder due to fouling while in flight (at high power settings) to be pretty unlikely.
mike.smith wrote:Onex107 wrote:The Aerovee is a proven engine, but, it must be assembled, adjusted, and maintained by you.
The advantages of the Aerovee are low initial cost, maintenance expenses, and overhaul cost. And, the Sonex line was designed with that engine in mind.
I agree. I have 220 hours on mine, and after the initial break-in of the engine and the AeroInjector, it's been pretty gas-and-go. I adjust the valves at least every 25 hours, get an oil sample report at every oil change (25 hours), and clean the air filter every now an then. In 3 years and 220 hours I haven't even yet had to replace a spark plug; just cleaned and gapped them. They've been in very good shape at each annual condition inspection. We'll see how they look this spring at the next inspection. I highly recommend getting oil analysis no matter what engine you have. If anything is going on in the engine, it will likely begin to show up as a trend in the reports.
When I had a prop strike a year ago I had the engine apart and cleaned in 2 evenings, and installed a new crank and bearings in 2 more evenings (doing that essentially means putting 90% of the engine back together again). If I had not been the builder of the engine the prop strike would have been a MUCH larger event. Incidentally the inside of the engine, including the crank and bearings, looked almost new. I replaced them from an abundance of caution, and because it would have taken too long and cost too much to send out the crank for inspection.
I've flown two trips to Oshkosh, totaling almost 4,000 miles with no mechanical issues. That was running the engine 10 hours a day.
My biggest "issue" with the VW is I can't seem to keep the right pushrod tubes from seeping oil. It amounts to maybe a teaspoon for every couple of hours of flight, so it's not enough to really even register on the dipstick, but it does register as drips on the pavement under my cowl. It's more of a nuisance than anything. I've tried several times to do all the things you're supposed to do to keep them from weeping, but so far I'm still trying. That's really a VW thing and not an AeroVee thing.
Onex107 wrote:
Mike I had the same problem, "caused by me" category. The tubes leaked on one side, the other side was tight. I didn't want to pull the head to do it again. I bought tubes from one of the VW supply sites that are two piece aluminum, one end threaded with double nuts and an O-ring. You take out the push rods, cut the old tubes out and install and tension the new ones. If any one still shows a little oil you take another turn on the lock nut. No more mess in the cowling.
John Monnett wrote:It is not true that the AeroVee was added to the Sonex as an afterthought. It is true the first Sonex (SX-1) was originally powered by a Jab but the design was conceived and built around the 80 hp VW conversion I was developing called the "AeroVee" for Sonex designs. It is, by far, the most popular engine choice.
John Monnett wrote:" but you'd have to admit that the airframe benefits from more horsepower as does the resale value. "
There is, of course, no substitutes for cubes in performance ( unless you have a jet)! But regarding higher resale value, it depends on a lot more than just engine size. Is the initial higher cost of of alternate (bigger) engines offset by the higher resale price? Instruments, workmanship miss. accessories, pressure and circumstances to sell all have a bearing on the resale value. In general some in the past, for the latter of those reasons, have established unfairly, a perception of a low resale market value for "used" Sonex aircraft that affects future sales. Some are just willing to take a beating for a quick sale driving the market down. BTW, This is not just a Sonex problem...
