by pappas » Wed Jul 19, 2023 8:55 pm
It's good to mention that I always keep my lap belt really snug. Usually just for turbulence. If the lap belt is loose and you tighten the shoulder straps, the only thing that happens is the lap belt rides up way too far and you are less likely to remain in the pilot's seat in the event of an incident. (in a 4-point harness system).
I knew that this landing was going to be a rough one so I prepared. 1st, I snugged the lap belt really tight, next I leaned back into the seat as far as I could and pulled the shoulder straps just as tight as I could get them, I shut off the fuel and switched off the ignition and all electrics. The last item was completed while still about 50 ft agl. Then the only thing I concentrated on was not stalling and not hitting anything that was solid and taller than about a foot. (I'm thinking 1500 LB 15-foot tall Saguaro Cactus here, after all, it is Arizona and there were quite a few staring right at me).
Sometimes we get a little good luck mixed in with our bad luck.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
