I transitioned from 20 years in a C-150 to my tri gear Onex with only one ride in the right seat of a Sonex tail dragger. I had ten hours of tail dragger time in a Champ. I suppose all that helped, but I was still surprised by the quickness of the Onex due to the lighter weight. The stick is very sensitive and light compared to the heaver Cessna. As a result, it leaped off the ground on the first flight due to my heavy handedness. Be gentle. The speeds are similar to the Cessna. It will fly at 60 - 70, climbs at 80 - 90, approaches at 80, flares at 60 - 70, and touches down at 45 - 50. Stall speed is 42 - 45 clean and dirty. The major difference is it is 30 mph faster than the Cessna, aerobatic, and not as stable. You have to fly it all the time. No hands off. Due to the folding wings, the flaps are only half as large as the Sonex and less effective. The ailerons are twice as big and more effective. The Aerovee is the perfect engine for this plane. With more HP everything above changes. With your experiance, you won't have a problem flying, your insurance company shouldn't be concerned. I'm currently at 280 hours (hobbs) on the Aerovee with no problems. If you have any questions, I'm at
flyvfr@comcast.net.
Onex107
