X0057 Flies!
Post stories/images of the first flight of your Sonex, Waiex, Xenos, or Onex here.
X0057 Flies!
Postby racaldwell » Sun Oct 03, 2021 6:57 pm
I made a 45 minute 1st flight in the Xenos. I went up to 5500 ft near the field so I could get above the clouds. At 40 knts on the sailplane ASI I still hadn't stalled but called it close enough for a 1st flight. Then I spent about 1/2 the time trying to get down. One of the squawks I had was my pitch spring was too strong of nose down so my trim could make it neutral in level flight but just starting to pull the spoilers got a big nose down pitch. SO I didn't use spoilers until I was slowed just over the runway. On the long descent from 5,000 ft, I approached Vne with no issues. On a long final, I used a full control forward slip to help slow and descend as I didn't want to test the large pitch down of the spoilers before I make an adjustment on the pitch spring. It all worked out fine. As I slowed and about 25 ft over the runway, I put in 1st notch of spoilers and the speed was slow enough then to not have much pitch moment. I touched down tailwheel then mains right after but I was going for a 3 pointer. The touchdown and roll out was smooth and straight down the centerline.
One of the squawks I have to address before next flight is to get more cooling air to cyl. #4. My plenum over the engine does not have internal deflectors yet but will have soon.
Another was the cowling internal airflow put enough force on my cowl flap to push the cable sheath inside the firewall fitting. I did hit 135 kts IAS for a minute. I'll make a strong stop collar for the cable to fix that one.
I'll make another flight next weekend.
Rick Caldwell
Xenos 0057 N137RC
Xenos Left Side Sm.jpg (191.94 KiB) Viewed 8294 times
racaldwell
Re: X0057 Flies!
Postby Scott Todd » Sun Oct 03, 2021 8:15 pm
Congratulations! Keep us posted on your progress.
Scott Todd
Re: X0057 Flies!
Postby WaiexN143NM » Sun Oct 03, 2021 8:58 pm
Hi Rick,
Congrats! great to hear, and thanks to all who helped you locally and on the forum!
Plane looks great, love the canopy.
Re: X0057 Flies!
Postby bvolcko38 » Mon Oct 04, 2021 8:32 am
Congratulations Rick! Long time coming, but worth the effort. My Xenos has a pronounced nose down pitch when spoilers are deployed as well. Nothing that you can't get used to though.
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: X0057 Flies!
Postby DCASonex » Mon Oct 04, 2021 9:28 am
Rick, Finally got that bird in the air. :-) Looks good.
Re: X0057 Flies!
Postby GraemeSmith » Mon Oct 04, 2021 9:32 am
Yay! - Great job!
Re: X0057 Flies!
Postby racaldwell » Mon Oct 04, 2021 12:05 pm
Thank you all and for the support you add to this forum. Lots of good info I have used during the build. I especially thank David A. for his good ideas. I used his prop spacer idea to move the cowl forward, his three piece cowling idea, and others that I can't remember to recall.
I had Saber Mfg. make a prop spacer and the smallest they could make was 1". I don't know what is stock for the CAMIT prop flange spacing set up for a Sonex but it looks like it is more forward than the original Jabiru. I had to add 1" to the cowling to get it to fit. The oil door outline in the cowling was 3" too far forward so I had to fill that in and cut a new oil door. So it looks like my cowl is 3" forward from original. But even so, there is now just enough space for the air plenum I made for the oil cooler air. And the odd cyl. side is still close to the inlet opening. I could not imagine not having this extra space to work with.
Rick Caldwell
Xenos 0057 N137RC
Xenos Left Cowl Inlet W Intersection Fairing Sm.jpg (178.48 KiB) Viewed 8135 times
racaldwell
Re: X0057 Flies!
Postby Sonex1517 » Mon Oct 04, 2021 1:42 pm
Congratulations! Fantastic news!
Re: X0057 Flies!
Postby Area 51% » Mon Oct 04, 2021 3:21 pm
Nice!!!!!!!!!!!
Can Bryan Cotton be far behind? By my recollection....it's already December 1009th.
Re: X0057 Flies!
Postby Bryan Cotton » Mon Oct 04, 2021 3:53 pm
Area 51% wrote:Nice!!!!!!!!!!!
Most important - congrats Rick!
I still have to send in the registration. I've not been focused.
Return to First Flights!
