Sonex 759 defies gravity for the first time
Post stories/images of the first flight of your Sonex, Waiex, Xenos, or Onex here.
Postby Sonex1462 » Wed Mar 09, 2016 11:56 am
Congratulations!
John Stewart
Sonex 1462
Kit, Aerovee, Tri Gear, ST Controls
Website: http://stewartaircraft.net
Sonex1462
Re: Sonex 759 defies gravity for the first time
Postby Jim B » Wed Mar 09, 2016 12:03 pm
Phil
Congratulation. My sonex was also my 3rd build.
Jim
snx760/jab2200 with a bing carb
Jim Ballenger
snx760/jabiru2200
first flight Sept 2009
Ocala,Fl
Jim B
Postby Sonex1517 » Wed Mar 09, 2016 8:04 pm
Congratulations Phil!
Fantastic looking airplane!!
Postby Corby202 » Wed Mar 09, 2016 9:43 pm
I would be interested in some close-up photos of the canopy bow. It looks nice, how did you do it?
Thanks, I will try and get some better shots when next at the airfield but basically the bows are drilled and tapped, covered in heat shrink tubing and glued to the canopy with Sikaflex along with the side channels which are also drilled and tapped. The black paint looking stuff on the canopy is the Sikaflex primer painted on the inside of the canopy. I did not countersink any of the plastic.
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Postby Corby202 » Wed Mar 09, 2016 9:50 pm
By my reckoning, that means building was a 40hr/wk "full time job" for a year for you! Wow, that's tenacity!
Well its probably more like 15 months, but I retired from work at the same time and was supposed to be a retirement project but I sort of got carried away as I was enjoying the building along with flying the Corby Starlet and Riding the Triumph I didn't have time for anything else that's for sure.
Phil Bird
Corby202
Postby Corby202 » Wed Mar 09, 2016 10:32 pm
Thanks for all the comments. I did the second flight today, 45 minutes, I took the GPS along for the ride and figured out the MGL ASI was the incorrect one so I recalibrated that, both ASI's read the same now. Got it back to 60 knots and tried out the different flap settings, the force required to get the 30deg of flap is more then I like. Opened the throttle at 3100 I was showing 120knots, I also need to add a trim tab to the rudder as I was constantly holding right rudder. The first landing was three touch and goes in quick succession so I powered on and went around. The next one was much better. The engine is running way to rich so I have to figure that out. I do like flying this plane though.
Phil Bird
Corby202
Postby tonyr » Wed Mar 09, 2016 10:35 pm
Congratulations Phil,
Beautiful job, well done mate!
Cheers
Tony
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby bakfly » Thu Mar 10, 2016 5:03 pm
Congratulations Phil and many happy and safe flying hours.
Your Plane looks very nice a job well done.
Cheers,
Peter,
Sonex 8464 Aerovee 2.1
Flown 105hrs.
bakfly
Postby fjdoug » Sat Mar 12, 2016 9:01 am
congratulations Phil,
i will have to make the short hop over to check it out.
Doug McLean.
ps hey Rizz ;
i was racing my windsurfer on Lake Illawarra today, saturday, when i reckon you came roaring overhead,
was that you ? !
fjdoug
Postby Corby202 » Sun Mar 13, 2016 10:05 pm
Come on over Doug, give me a ring and I will make sure I am there. 0491131963
Phil Bird
Corby202
Return to First Flights!
