Fire extinguisher
Fire extinguisher
Postby kmwoody » Sun May 04, 2014 12:18 pm
Hi all,
My Sonex has a fire extinguisher installed in front of the flap rod on the passenger side. It would be useful on the ground but if I needed it for an inflight fire I would have to take my harness off and loosen my seatbelt to retrieve it. That I am not willing to do. I am either going to move it to a different spot or remove it. My question is, are others carrying a fire extinguisher?
Ken W
Sonex 959
kmwoody
Re: Fire extinguisher
Postby vigilant104 » Sun May 04, 2014 3:00 pm
Ken,
Yes, I have a small one that Jay mounted in front of the flap rod on the pilot side. Could you reach the extinguisher if mounted there? Higher up on the spar enclosure?
If there's a fire in the wires/instruments in the panel, I suppose an extinguisher might be useful in flight (if it didn't go out after turning off the master switch). And I'd be happy to have it if there was a fuel leak and fire inside the cabin. I can't see much use for it in flight if the fire is on the engine side of the firewall--best to let the firewall do its job while I expedite a descent to the nearest safe flat spot. I've wondered if anyone has rigged up a way to use the same extinguisher to address a fire under the cowl, and if such a setup would be worth the weight/hassle. Maybe if one flies a lot over water/solid forest/rocks, etc.
Mark Waldron
Aerovee, Trigear
vigilant104
Postby fastj22 » Sun May 04, 2014 6:21 pm
I have a small halon mounted on the floor just forward of the flap rod. I would need to unbuckle to reach it in flight. But my primary reason to have on is a ground incident where I might have a fire and can't extract myself. At that point, I'm out of the harness and trying to save my own bacon.
As for an inflight fire, firewall forward, first thing you would do is cut off the fuel. That would probably extinguish the flames quickly. Not sure an onboard fire suppression system would be of much value.
Postby kmwoody » Mon May 05, 2014 6:31 pm
Thanks for the replies. It seems not many carry an extinguisher onboard. About the time I remove it will be the time that I need it. I might order a smaller 1 lb can instead of carrying the 2.5 lber I have now.
Ken W
kmwoody
Postby hickej » Wed May 07, 2014 3:15 am
I mounted a small one behind the turtle deck bulkhead so I can easily reach it while buckled in.
hickej
Postby JerryCPP » Wed May 07, 2014 6:31 pm
I mounted a small extinguisher and mount from Aircraft Spruce above the flap rod between my knees. I can unlatch it while sitting strapped in.
JerryCPP
Users browsing this forum: No registered users and 88 guests
