Page 1 of 2
Radio noise
Thu Apr 03, 2014 8:27 am
by Glenn.hunt
I am getting ignition ticking through the radio. Reception is not too bad but my transmissions are not very clear when revving over 2000rpm. I have the Aerovee. Has anyone had any experience/success in dealing with this? I have tried ferrite beads on the power feeds in various locations and on the coax cable but no help. I have checked all the usual culprits ( grounds etc) with no luck also.I remember some of you using noise filters and/or capacitors.
Glenn Hunt Sonex N414SX
Re: Radio noise
Sun Apr 06, 2014 7:38 pm
by Gibbsfamily1
I used a noise filter. The type I used had both a positive and negative circuit. I believe it was a Pyramid brand designed for high end automotive audio. Not a peep after it was installed.
Re: Radio noise
Mon Apr 14, 2014 6:12 pm
by billmaxmcw
Can you get more specific on the filter and where it is installed? I have ignition noise in my Sonex/Aerovee which goes away when I switch off the primary ignition. I have shielded wires to the primary ignition switch. Any other suggestions are welcome.
BIll
Re: Radio noise
Mon Apr 14, 2014 7:19 pm
by Glenn.hunt
That's funny, my primary is quiet. It's the electronic ignition that makes the noise.
I too am interested in Mr. Gibbs response about which filter and how/where to wire it.
Re: Radio noise
Tue Apr 15, 2014 11:07 am
by billmaxmcw
At first, I had my radio teed into the ELT antenna under the windshield, like a factory plane, and the noise was bad. Got much better after using a larger antenna on the turtle deck.
Re: Radio noise
Fri Apr 18, 2014 5:28 pm
by billmaxmcw
Glenn.hunt wrote:That's funny, my primary is quiet. It's the electronic ignition that makes the noise.
Since the secondary ignition fires the bottom plugs, it should interfere more with bottom-placed antennas. Where is your antenna?
Bill
Re: Radio noise
Fri Apr 18, 2014 7:39 pm
by Glenn.hunt
On turtle deck, one bay behind seat.
Re: Radio noise
Fri Apr 18, 2014 7:42 pm
by Glenn.hunt
I remember a while back someone specking a Pyramid noise filter. I am just curious as to where it is wired into the system.
Glenn
Re: Radio noise
Fri Apr 18, 2014 8:26 pm
I would suspect that if it is wired into the aircraft, it is taking noise out if power and not out of the air. So, I would wire it near the power in of the radio. Perhaps I am not understanding the filter though.
Re: Radio noise
Sat Apr 19, 2014 5:02 am
by Brett
Probably seems rash but I cut the copper cored leads off my primary ign as close to the magnetron coils as I could and installed ign lead joiners from" narva" and used normal automotive ign leads like on the secondary ign wires. So far after 50 hours I have no noise from my primary ign now and still fires the plugs ok....hopefully will be ok long term. When I emailed sonex they said I must have a radio installation problem and I probably did but this fixed it so that's how it's staying for now.
