Bent Nose Gear
Bent Nose Gear
Postby Major4567 » Mon Mar 31, 2014 7:21 pm
I was wondering if anyone else has had issues with the nose gear bending at the forks? Have you done anything to correct the issue?
Waiex, Jab 3300
Major4567
Re: Bent Nose Gear
Postby fastj22 » Mon Mar 31, 2014 7:51 pm
Yes. I bent mine at the forks. Like a grocery cart that was slammed down. Made my plane pull to the right during taxiing. I had thought it was a grabbing brake or wheel bearing.
After one flight, I left the plane outside the hangar to go to the bathroom which is at the end of the row of hangars. On walking back to the plane from a distance I noticed the wheel canting to the side. Not really noticeable while doing a preflight up close.
Seems one of my later landings which wasn't much to write home about did it in. I remember one where I was exploring the edge of my reserve lift gauge and plopped down rather hard. Probably that one.
I had intended to convert to a tail dragger and had purchased everything necessary to make the change but was having too much fun flying.
The episode forced the issue. I'm now a happy taildragger.
Re: Bent Nose Gear
Postby kenh3510 » Fri Apr 04, 2014 3:10 pm
I also bent my nose gear after a hard landing and had to completely replace it. The forks were too bent to attempt straightening. As I look at the bent gear I wonder if there is a way to strengthen it. Haven't made a hard landing since then, good teaching moment.
kenh3510
Re: Bent Nose Gear
Postby Onex107 » Fri Apr 04, 2014 3:56 pm
I bent my Onex nose gear in a snow bank. I ordered tubing from McMaster Carr and a friend welded the fork on. $50.00 versus several hundred from Sonex.
Users browsing this forum: No registered users and 79 guests
