uteboy wrote:I had heat issues with a small engine bay in a car I built that had a V8 fitted. The thing that made the biggest difference was allowing the under bonnet (hood) air to escape more easily. I did coat the headers on the outside surface with ceramic which was not a cheap excercise but I cannot say that it made a huge difference to temps but it did eliminate corrosion as ten years on not a spot of rust anywhere.
Andy Walker wrote:You might get better flow-through by putting extra/larger holes in the bottom rear of the cowl to allow air to flow out, but then you might not get enough pressure under the cowl, which is also critical to cooling.
