Tire pressure?
Tire pressure?
Postby Tony4aro » Wed Feb 05, 2025 10:27 pm
Easy question..... what's the proper pressure for the tires in a Sonex/Waiex? Also.... I got my Airworthy cert today !!!!!!!!
Corvair powered Waiex (under construction)
N3848D
W0181
Tony4aro
Re: Tire pressure?
Postby Skippydiesel » Wed Feb 05, 2025 11:55 pm
Congratulations!
Tyre pressures - check with your tyre manufacture for pressure range.
My Legacy has Goodyear, Flight Custom III, 5.00 – 5, 6 ply, which I inflate to 40 psi
Skippydiesel
Re: Tire pressure?
Postby Bryan Cotton » Thu Feb 06, 2025 12:24 am
Congrats! 45-55 psi. I usually fill to 55 and am happy with anything 45+. If you do 30 psi like on the casting, the tire & tube will spin and tear the valve stem.
Re: Tire pressure?
Postby Skippydiesel » Thu Feb 06, 2025 6:38 am
Hi Bryan,
Do you think it would help if you mentioned the tyre brand, model & ply rating?
Skippydiesel
Re: Tire pressure?
Postby Tony4aro » Thu Feb 06, 2025 7:49 am
Thanks for the info so far. Right now... they are just the factory tires. Over the years, I remember people saying to run more pressure than the wheel casting said. And.... the inspector yesterday was telling me of a pits that went over on it's lid because a tire was very low. (Bad ground loop on landing) Eventually, I will put on some 5.00x5 tires.... but for now... it's just the little stock ones.
N3848D
W0181
Tony4aro
Re: Tire pressure?
Postby DCASonex » Fri Feb 07, 2025 10:10 am
Have about 500 hours on my Sonex, all with the 5.00 x 5 tires. The 50 PSI Sonex calls for may be right for the standard small tires, but with the 5.00 x 5 tires, I find 25 PSI quite adequate. As I recall. the aluminum wheels are marked 35 PSI max, and while they seem to be perfectly okay with the small tires, the increased sidewall area of the larger tires puts additional stress on the wheels so staying closer top the wheels maximum rating seems prudent with the larger tires. I know some will immediately think that air pressure is the same everywhere, why should tire diameter matter, but the added side wall area means more total force applied trying to spread the two halves of the wheel and bolt failures in those wheels has been known to happen. (I replaced my bolts with aircraft grade ones.)
Re: Tire pressure?
Postby MichaelFarley56 » Fri Feb 07, 2025 10:39 am
I always used the factory Chen Shin (sp?) 11-4X5 tires and inflated them to 45 psi and never had any issues. They do a remarkably good job holding air! I normally checked them every 2-3 months and they never lost more than a few psi.
Re: Tire pressure?
Postby Tony4aro » Fri Feb 07, 2025 12:52 pm
Thanks guys
N3848D
W0181
Tony4aro
Re: Tire pressure?
Postby Sonerai13 » Sun Feb 16, 2025 5:21 pm
When I was working at Sonex, I always ran the tire pressure on the factory airplanes at 45 psi. Seemed to work great.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Re: Tire pressure?
Postby Skippydiesel » Sun Feb 16, 2025 6:46 pm
Sonerai13 wrote:When I was working at Sonex, I always ran the tire pressure on the factory airplanes at 45 psi. Seemed to work great.
The assumption that ALL Sonex are using the mythical Sonex standard tyre(???) is plain weird.
How about respondents quote the tyre make, size, ply rating and might also be helpful to disclose, mostly sealed/grass runways.
AND
If there is a particular rationale for their preferred pressure eg Manufactures Recommendation, etc
Skippydiesel
