oilite bushings lubrication
Postby Murray Parr » Sat Dec 28, 2024 7:44 pm
What do you use to lubricate oilite bushings at each annual?
Is there a spray lube that is good for this, or do I have to disassemble things each time?
Is it better to just trust that they are pre lubed for life?
Note: I also forced more oil into them upon assembly by squeezing oil between my thumb and finger as I learned during my mechanical apprenticeship years ago. Seemed to hold up for many years just by doing that on generator bushing etc.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Re: oilite bushings lubrication
Postby n502pd » Sat Dec 28, 2024 11:01 pm
Hello! first NOT wd40! Or 3 in one. I have used spray white grease for the outside areas, after dribbling TRI FLO ptfe lube on the bushings. I do agree with the finger squeezeing, but I am not really wanting to take things apart that far unless there is a real problem. Of course, how much TT is on the mechanicals may determing how many times relube may be necessary. Bear in mind, N502PD is still a youngster at 82 tt, but I do relube. Let us know what you decide to do! Happy Hollidays!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby Murray Parr » Sun Dec 29, 2024 5:02 pm
n502pd wrote:Hello! first NOT wd40! Or 3 in one. I have used spray white grease for the outside areas, after dribbling TRI FLO ptfe lube on the bushings. I do agree with the finger squeezeing, but I am not really wanting to take things apart that far unless there is a real problem. Of course, how much TT is on the mechanicals may determing how many times relube may be necessary. Bear in mind, N502PD is still a youngster at 82 tt, but I do relube. Let us know what you decide to do! Happy Hollidays!
Thanks Joe,
I only do the finger squeezing the oil in when installing new, the airframe only has 35 hours, so I definitely won't be taking them apart yet unless I find an issue with any of them. Maybe I will start re-lubing with some sort of spray lithium or graphite grease but for now, I think everything is still too new to be of any benefit.
Wondering what most people are using? I might also reach out to Sonex to see what they do with their fleet or maybe they will chime in here.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
RV9 builder (Sold)
Murray Parr
