Crankshaft failure in flight, lost propeller, no injuries
Posted: Wed Nov 15, 2023 12:46 pm
The saga continues…
After spending 4 days stuck in Ohio facing ignition and vapor lock problems (both resolved thanks to the help of some A and Ps and these forums), I departed solo on my way back home to Maine. In the final 20 mile stretch flying from KPOV to KOLE I started experiencing some minor vibrations. I tried adjusting mixture and power settings, and running on either ignition to no avail. Within 2 minutes the vibrations had increased to the point that the entire instrument panel was unreadable. At this point I switched to 121.5 and my propeller, spinner and, flange completely departed the aircraft. The engine spooled up after this and ran fine. I declared an emergency and glided to a road underneath me. Luckily landed safely with no damage to the airframe or anything on the ground. Crankshaft cracked right at the front main seal. Prop bolts had been retorqued ~20 flight hours before. The engine had the older model of crankshaft, was not an aerovee 2.1. Unsure if this potentially is related to the crankshaft failure. Very glad to have had a long straight road right underneath me, and that this resulted in the safest possible outcome. Bummed the plane will be down for the foreseeable future :(
Images after landing:
https://postimg.cc/gallery/nBwXgpj
Some news articles:
https://www.oleantimesherald.com/news/f ... e9e0d.html
https://wellsvillesun.com/blog/2023/11/ ... us-county/
https://www.nyspnews.com/emergency-land ... te-417.htm
Some news articles:
