Greetings builders,
Some of you may be familiar with the homebuilt HELP series. One of his videos is on polishing aluminum parts (really Deburring and beautifying, I'd say)... In the video below, at about the 2:20 mark, he goes through the process of rounding off the corners and polishing up the faces of the aluminum bracket he's showing...
Ignoring the obvious benefits of deburring, my questions are these: Is processing the parts like this adding any engineering value or is it all aesthetic? Would you do this on all interior parts, from the smallest brackets to main spars for the flight surfaces? He mentions places where corner rounding would NOT be advised, but doesn't really explain why - anyone have a guess?
And finally, aside from edge deburring, how have you all prepped your factory aluminum parts before assembly?
https://youtu.be/JdBA4BCsQ0MThanks,
Devin
