Rough Engine
Rough Engine
Postby Friesen5 » Wed Apr 19, 2023 1:30 pm
My Sonex with a Jab 2200 has been flying since 2007 and has 480 hours. I just completed my annual this spring and was preparing for a test flight. The engine started but was running quite rough. Further testing revealed that cylinder #1 was the likely problem. I conferred with several friends and came to the conclusion that it was likely a valve problem. I started by removing the valve covers. I discovered the valve adjuster laying in the cavity.
I replaced it, adjusted it to .010" and put the valve covers back on. Now when I started it, it ran smoothly. I put the cowls back on and went for a test flight. The engine was smooth and ran well.
How did the adjuster get so loose that it actually came out of the rocker? I don't know the exact answer, but probably I didn't tighten it sufficiently when I did the annual in March.
I'll be mindful of that every time I check the valves in the future.
Mervin Friesen
Friesen5
Re: Rough Engine
Postby Skippydiesel » Wed Apr 19, 2023 6:03 pm
"To err is human, to forgive divine" - we all make mistakes, don't beat yourself up too much.
Thank you for your courage in reporting your incident - it is stories like this, that keeps all of us alert to our own potential to make a simple, possibly catastrophic, mistake.
Skippydiesel
Re: Rough Engine
Postby pappas » Thu Apr 20, 2023 9:54 am
What a lucky guy you are! My Aerovee Turbo snapped the valve adjuster while at 3500 ft over the desert. You need to buy a lottery ticket, pronto!
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Users browsing this forum: No registered users and 47 guests
