Alternate Canopy Latch / Lock Mechanism
Posted: Sun Dec 01, 2013 3:37 pm
In the 9 years I have been building I have been mulling over different ways to latch / lock the canopy. Although it is probably the simplest method I just never liked sonexs the idea of cutting a slot in the canopy that leaked air and water and having a big old pad lock hanging off the side of the plane when you wanted to secure the canopy. A couple of North East Sonex gatherings ago there were a few planes that flew down from Canada that utilized a plate that slid on bushings to push the canopy latch back and forth. I liked the idea but wanted to come up with something other than bushings as it seemed like getting them adjusted just right so that they slid but didn't have excess play would be a bit of a pain. What I came up with was to use an inexpensive piece of ball bearing drawer slide from home depot as the slide mechanism. This made it so there was no adjustment necessary and the mechanism slid very easily back and forth with almost no looseness. Below is a picture of what I came up with.
The drawer slide basically got two pieces of angle riveted on to it that capture the feet of the canopy lock bar. There are two custom made stops made out of 0.063 on either side and a set of springs to open the mechanism when it get unlocked.
You can see from the other side that I made a pin that was bolted to one of the angles so that the pin stuck out of the fuselage and provides a means to move the mechanism back and forth.
Here it is installed on the plane. Everything was kept nice and short so no part of the mechanism stuck out past the upper longeron. One of my concerns was if it would get in the way of my shoulder but since the mechanism is pretty narrow it seems to stay nice and clear. You can also see in that picture exactly how it grabs the lock bar. It is in the unlocked position in that picture.
Here it is in the locked position. You can see the bar off the key lock that comes up and holds it there. I have a little more tuning to do on the arm so that it is nice and vertical when in the locked position.
And here is the picture of what it looks like on the outside. This in in the unlocked position. To lock it you just slide the pin to the left and lock it in place with a key. It is certainly heavier and more complex than the sonex plans method but it met my criteria of being weatherproof and not requiring an additional holes or slots in the canopy.
#554
#554
