Edge distance
Posted: Sun Nov 24, 2013 10:14 am
Hi all,
I have a question into Kerry at Sonex, but would solicit your experience too. One of the things I find challenging in this build is that many parts are designed around using minimum edge distance as the norm, i.e. 1/4" for 2D. When parts line up with edges on either side of the line, you have to get it perfect on both parts. My drive horns were hitting the skins on the ruddervators. Trimming for clearance I lost 1/16" of edge distance. This is probably why they have you rivet the horns on first, though I did not for the sake of easier of assembly. My bad. I can either rivet a joggle strip on the inside, or scrap and start over. Anybody else do something similar?
