Darick wrote:Thanks for the reply. Hope your phase 1 went smoothly.
Darick
MichaelFarley56 wrote:You've hit one of the more interesting aspects of building a Sonex Darick. From what I've gathered, there used to be a simple build manual but those are no longer being offered.
Believe it or not, your build manual and procedures is your drawing tree, plans page # SNX-B03 (or close, I'm sure you know which I'm talking about). That is your outline for building and if you take a look at it, you'll see there's a method to the madness. Sonex give you the option of where you start; fuselage, wings, tail, etc. Most start at the tail so if you look at the drawing tree, look at the pages that SNX-T##, highest numbers first which are at the bottom of the page. Think of it literally like a tree and start as the "highest" branches. There will be a sub-assembly page to start, then a main assembly page, etc. It follows an order. SNX-F## is fuselage, SNX-T## is tail, SNX-W## are wings, etc.
Make sense?
Thanks!
Users browsing this forum: No registered users and 112 guests
