Undersize Hinge Pins
Postby kmacht » Fri Sep 20, 2013 2:34 pm
I have heard of people buying / using undersize hinge pins to make putting the cowel on easier. Does anyone know where to get them? I need to make my gear leg fairings and just realized last night that I have plenty of hinge leftover but no more hinge pin. Somewhere in the last 9 years of building some pieces must have gotten lost. Before I just go order some more stock hinge pin from wicks I figured I would look into getting some pins that were just undersize to make inserting them easier. Anybody know where to buy them?
Re: Undersize Hinge Pins
Postby Mike53 » Fri Sep 20, 2013 5:49 pm
I don't know if they will sell only the pin but you can ask.If not it's still pretty cheap considering the benefit.Good idea ,think I'll do the same :idea: http://www.vansaircraft.com/cgi-bin/sto ... duct=hinge
Antoine de Saint-Exupery
Mike53
Postby rk2436 » Sat Sep 21, 2013 12:09 am
You can use music wire from a local hobby shop.I forgot the exact size needed but is's easy to find the correct one. I used a smaller size on the lower cowl hinge and copied Gus S 's idea of putting it in from the bottom and going right thru the cooler opening to a small section of hinge riveted to the area where the plans show a south co.
Bob K
Orig builder kit 1143
Now flying RV-12
Evergreen Park,Il
rk2436
Postby rk2436 » Sat Sep 21, 2013 12:11 am
Buy the straight sections only,if u order some online they will coil it up .
Bob K
Now flying RV-12
Evergreen Park,Il
rk2436
