Rivet Rattle Noise
Rivet Rattle Noise
Postby Bacon8tor » Fri Sep 13, 2013 4:34 pm
I just started on a Onex tail assembly and have no previous experience with aircraft building. After riveting the control surface rid to the rudder drive horn to produce the rudder drive horn assembly, I could hear a rattle noise coming from one of the rivets which I couldn't isolate. Fearing a bad rivet I removed all of them, put in new rivets, and got the same rattle noise. Is this common for pop rivets?
John Bacon
Henderson, NV
Onex 164 N702JB Reserved
95% done.....
Bacon8tor
Rivet Rattle Noise
Postby Sonex1517 » Fri Sep 13, 2013 5:20 pm
That's normal - you will hear some rattling from the rivets. As I mentioned in my other post - contact tech support when you aren't sure!
You could potentially do more harm drilling out and re-setting rivets when it may not be needed....
Robbie
Re: Rivet Rattle Noise
Postby Bacon8tor » Fri Sep 13, 2013 9:08 pm
Thanks, Robbie. I'm hesitant to contact tech support as a newbie with what most might consider a dumb question. But I'll take advantage of the service they offer in the future for the big questions.
John Bacon
Henderson, NV
95% done.....
Bacon8tor
Postby fastj22 » Fri Sep 13, 2013 9:28 pm
The rattle is probably the mandrel head rattling around in the mushroomed head of the rivet. Since its sheared off during pulling, it has done its job and now it just wants to annoy you. If it bugs you, punch the edge of the mushroom to silence it or squeeze it with pliers. Or wear ear plugs or turn the music louder in your shop.
