Taper pin reamer
Taper pin reamer
Postby bvolcko38 » Sat Apr 25, 2020 8:56 am
My left seat joystick is developing a bit of play. I think it needs a taper pin. I borrowed the "community" taper pin reamer a couple years ago and sent it back out to the next guy that needed it. Does anyone know where it is?
Regards,
BV
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: Taper pin reamer
Postby Spaceman » Sat Apr 25, 2020 9:17 am
I think I have it! I'll look for it today
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby Sonex Foundation » Sat Apr 25, 2020 9:52 am
Once you guys are done with it, let me know. I will have you ship it back.
Which reminds me that I have one of David A’s tools to return!
President
Sonex Builders and Pilots Foundation
http://www.Sonexfoundation.com
Sonex Foundation
Postby Spaceman » Sat Apr 25, 2020 3:59 pm
I found it! Bill if you want to PM me your address I'll get it in the mail next time I leave the house.
Chris Paegelow
Spaceman
Postby DCASonex » Mon Apr 27, 2020 9:48 am
Learned long ago that when something is everybody's responsibility, it is nobody's. That is the reason why I have not donated to the foundation, the two tools I keep sending out. Suggest having one active member of the foundation be placed in charge of maintaining, tracking and insuring the return of tools.
Postby OneTallShort » Wed Apr 29, 2020 3:43 am
Is there a #2 taper reamer being passed about, or is it just the #1 size? I'm looking for a #2 Brown and Sharpe taper reamer for my control sticks. I'm pretty sure that's the size needed to replace the AN4 bolts.
Gregg Short
SX-715
(330) 465- seven five three 1
OneTallShort
Postby GordonTurner » Wed Apr 29, 2020 7:09 am
I have just ordered a #1 and #2 B&S reamers from Aircraft-Tool.com. Their price was about 1/3 of AS price.
Mistakenly ordered same previously from MSC, and found out the hard way that aircraft reamers are NOT the same as standard #1 and 2 reamers, which are MUCH smaller. You have to track down the Brown&S ones.
Gordon
Postby Sonex1517 » Wed Apr 29, 2020 7:44 am
Here is the information on the reamer being passed around from the foundation:
This reamer is a B&S #1 size and will taper holes for the AN 386-1-8 taper pin.
Available:
B&S Taper Reamer #1
Postby Spaceman » Wed Apr 29, 2020 11:23 am
OneTallShort wrote:Is there a #2 taper reamer being passed about, or is it just the #1 size? I'm looking for a #2 Brown and Sharpe taper reamer for my control sticks. I'm pretty sure that's the size needed to replace the AN4 bolts.
Gregg Short
SX-715
I found that I could get large enough holes with the #1 reamer even for the larger pins just by drilling farther into the parts with it. For whatever that's worth!
Chris Paegelow
Spaceman
Postby OneTallShort » Thu Apr 30, 2020 1:58 am
Chris,
Thanks for that info. That may save me $40 if I can borrow the #1 reamer when Bill is done with it!
OneTallShort
