Buying used plans
Buying used plans
Postby wvshooter » Wed Jun 26, 2013 8:02 pm
I need a set of Sonex plans and would like to buy used? Where should I look and what should I know about buying used plans?
wvshooter
Re: Buying used plans
Postby N111YX » Thu Jun 27, 2013 3:24 pm
There's a set on barnstormers.com right now. You'll have to "transfer" ownership of the plans through the factory for support...
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby fastj22 » Thu Jun 27, 2013 8:13 pm
Make sure you have rights to buy the spar caps from Sonex before you buy. If the original owner bought the caps and sold them to someone else, your plans would be worthless. One set of spar caps per set of plans. If you damage your caps, you need to document the damage and convince Sonex you are entitled to a replacement. Its their way of preserving the license to build.
Postby floridasonex » Sat Jul 06, 2013 7:52 am
Would a person not be better off buying the latest plans from Sonex with all the current changes incorporated in them. It seems that saving a small amount up front would be a false savings without all the latest info in them.
RT
#1579
Trigear Aerovee Sonex 1579
Flying since 4/1/13
floridasonex
