ADS-B, where is your head?
PostPosted: Sat Apr 21, 2018 7:18 pm
by fastj22
As the deadline approaches, how is everyone approaching it?
Go with certified solution?
Go with experimental solution, (integrated xPonder)?
Go with a solution that will leverage your Mode C xPonder?
Avoid Mode C veil airspace and above 10,000 MSL?
Some of us early adopters have gotten burned (NavWorx), some are swinging in the wind, some are pretty darn happy.
I'm in the middle. Bought a SkyguardTWX 2 years ago and had a few upgrades. When I fly, I check with with FAA website to get a report. Its throwing some errors, not sure I'm compliant, the GPS drops out so I assume it effects the report. I hear nothing from SkyGuard, he hasn't been to the last two AirVentures, but haven't call them in a year either.
I've helped install to Uvonix units in other Sonex and they seem solid.
Garmin, Dynon, Sandia, Grand Rapids are all coming out with affordable integrated solutions.....if you think $3000 is affordable!
Re: ADS-B, where is your head?
PostPosted: Sat Apr 21, 2018 8:21 pm
by Sonex1517
Personally, I am waiting as long as I can. But since my home base is under the edge of the O'Hare Mode C veil, I will have to bite the bullet before the deadline.
I have a GRT Mini and am going to install the echoUAT/Safe-fly GPS Package - current price is $1490. I already have a Garmin transponder installed.
For ADS-B In, I use a Stratux connected to the Mini. Today on a short flight I got weather and traffic with 6 towers being received.
PostPosted: Sat Apr 21, 2018 8:25 pm
by mike.smith
I already had a Sandia transponder, so I installed the Uavionix echoUAT with a WAAS GPS on the glare shield. I got it installed in a total of 7 hours, and I've gotten 100% positive feedback from the FAA. I see the local traffic and weather on my Nexus tablet running Avare, and I'm 2020 compliant. I'm happy, and the price was right.
http://www.mykitlog.com/users/display_l ... 9578&row=4
http://www.mykitlog.com/users/display_l ... 9579&row=3
http://www.mykitlog.com/users/display_l ... 9952&row=2
http://www.mykitlog.com/users/display_l ... 0113&row=1
My home airport is within the Mode C veil around Boston, so I had no choice. But I fly through and into controlled airspace all the time, so it wasn't a question of "if," only "when." And I'm sure by now everyone knows if you are only getting ADSB-In you are NOT getting all the traffic! You may not be getting traffic that's 10' off your wing tip.
I got burned by NavWorx, too!
PostPosted: Sat Apr 21, 2018 8:30 pm
I don't live under the veil. No rush for me.
PostPosted: Sat Apr 21, 2018 9:36 pm
by Sonex1517
Mike
Did you do the install yourself?
Bryan - I envy you for being outside the veil!!
PostPosted: Sat Apr 21, 2018 10:52 pm
by mike.smith
Sonex1517 wrote:Did you do the install yourself?
Yes. The Kitlog entries are me doing the work.
PostPosted: Sat Apr 21, 2018 11:27 pm
by fastj22
I live just outside the Denver veil, but I also sometimes fly into KAPA to work on nice days. And Gary is on the other side, so either take the great circle route or fly right through it.
PostPosted: Mon Apr 23, 2018 10:02 pm
by n307tw
Currently building the panel. Was going to go with the all in one ADS-B in/out Sandia STX-360 but the offer from Uavionix has a better deal and is a ForeFlight partner so I am getting the Sandia mode-c remote head transponder and the Uavionix ADS-B in/out with WAAS gps and going to exterior mount the antenna next to the Sirius antenna on the turtledeck. Mounting the transponder and Uavionix heads under the seat but I don’t have autopilot so I may have a little more available room than you. Everything is going full remote controlled with the MGL EFIS Explorer so nothing else will be on the panel except a flush mount mini iPad. Looks relatively simple to wire up the Sandia and Uavionix because its all CAN bus or RS-232 linked. Like Mike Smith I’ll be under the Charlie veil and the NYC bravo mod-c ring is 10 miles to my East so the ADS-B stuff is required for me. Excited to see how the Uavionix will work with the iPad using ForeFlight or maybe switch to WingX. I know it’s off topic but I am really excited to install the Garmin GTR-200 radio also as it allows audio input from the MGL, audio input from the iPad, and stereo audio jack from the satellite radio. Has the two place intercom built in, transmits @ 10 watts and mutes music when there’s activity on the radio. Also allows you to listen to two frequencies for ATIS and main freq monitoring. All around sounds like a great radio and it’s cheaper than the MGL V6/V16. Good luck with your ADS-B choice and install John - keep us updated.
PostPosted: Tue Apr 24, 2018 3:33 pm
by bakerde36
I have a question. I do not have a transponder and wondered what would be the best/cheapest way to get compliant? I am in no hurry as I do not fly into class c right now. I do have a king KT 78 but it doesn't have the digitizer should I use this or is it too old and to costly to get a digitizer? Thanks all
PostPosted: Thu Apr 26, 2018 3:11 am
by SNX1508
bakerde36 wrote:I have a question. I do not have a transponder and wondered what would be the best/cheapest way to get compliant? I am in no hurry as I do not fly into class c right now. I do have a king KT 78 but it doesn't have the digitizer should I use this or is it too old and to costly to get a digitizer? Thanks all
I am in a similar situation, no hurry to have ADS-B out, don't fly in class C, but would like to see all traffic. Currently have a Stratux setup for ADS-B in only. I bought a KT 76 cheap, got the altitude encoder from Aircraft Spruce for $275.
http://www.aircraftspruce.com/catalog/a ... ncoder.php
I will be buying a echoUAT + SkyFYX GPS soon.
