messydeer wrote:Hey, guys :-)
I'm replacing my Odyssey PC625. Looks like the EarthX 680 and 680C would work. The C is 2" shorter and am thinking I could use that space. Any other considerations about making such a change?
I've not seen any fires from the batteries. I have seen the charging system damaged on a Jabiru with the damage credited to the EarthX battery charging demands. However, that is mostly due to the underdesigned wiring and connectors in the Jabiru charging system. The Jabiru is a 20 Amp dynamo type system that is not designed to carry a continuous 20 Amp load. The wiring connections are underdesigned. The problem with this charging system and the EarthX or any Lithium Iron battery is that while the battery can deliver huge amounts of amperage all at once, it also wants it back all at once once you are started and charging. If the charging system has poor quality connections, or a regulator or stator coil that will overheat at full load, then a Lithium Iron battery may not be the right choice.
In the case of the Jabiru that failed, the dynamo charging system does not charge at idle. The new owner spent an inordinate amount of time on the run-up pad while working his way through the various menus in the Dynon SkyView system in his new plane. The battery was just about to the low voltage cutoff point when he finally pulled onto the runway for take off. Once the engine was spooled up, the charging system went full tilt trying to recharge the EarthX battery and continued to charge at 20 amps until the charging system went off line. The connectors between the stator coils and the voltage regulator had melted (common problem with the Jabiru at high charge) and the solid state voltage regulator failed (also not an uncommon problem). Shortly after the charging system went off line, the battery had discharged to the safety cut off, so the battery also went off line, as did the Dynon system (battery backup was misconfigured). This was the second time he had done this. The first time the charging system survived, but the battery management system on the EarthX battery had failed taking the battery off line. EarthX did warranty the battery.
The lesson here is to make sure your wiring, connections, and charging system are properly configured to run at max charge as the EarthX battery will take a charge significantly faster than a lead acid battery, so can stress your charging system.
FWIW, I have been really happy with the EarthX I have in my other plane. I'll likely switch the SC Clone over to an EarthX when the current AGM battery expires.
LarryEWaiex121 wrote:The battery will slowly go from about 14.3 volts to 13.9 and that's where it stays, until the load is removed. It will then return to 14.3 with a simple 2 amp draw from Dynon panel and radio. ... I don't know if its the battery or the alternator that doesn't keep up?
Users browsing this forum: No registered users and 57 guests
