MichaelFarley56 wrote:I’m really glad to hear damage to your airplane was minimal, and I’m sure someone on here will have a prop for you to purchase.
I’m sorry to bring this up, but in the interest of safety, I have to ask; how did you determine the crank was okay? I assume you did have a prop strike, correct?
The only reason I ask is the VW cranks aren’t exactly known for being ultra robust, and more than one Sonex has suffered an engine failure as a result of a failed crank long after a prop strike took place. I’m not telling you what to do here, but if it were me, given the low cost of these cranks from the factory I would strongly consider just installing a new one so there’s nothing to worry about. It’s certainly your decision!
Best of luck getting your plane back together!
mike.smith wrote:When I had my prop strike I replaced the crank and bearings. When I went to remove the gland nut by anchoring the prop hub flange I found the crank was rotating inside the prop hub! The prop strike had sheared the woodruff key on the end of the crank. When I got the prop hub off I saw 1/2 of the woodruff key was firmly cemented inside the recess in the crank, and the other half had damaged the inside of the prop hub due to the shear forces put on them. So I was happy that I had decided to replace the crank, as the original wasn't reusable even if the rest of the crank was OK.
I now have much more respect for high cross winds and/or gusty conditions during taxi.
