I'm a huge advocate of & for the center stick for a few reasons, safety first of all. I had a center stick in my nose roller VW powered version and now in my Corvair powered tail dragger. But perhaps one of the best reasons for me personally is space. Some time ago on another forum far away I wrote concerning how the center stick was part of my personal endeavor to maximize the small space of the Cleanex cockpit.
Before anyone asks, here is an edited version of those notes:
In my Cleanex (notorious for a small cockpit area) I tried to do everything possible to maximize that available space. These things included:
1) Using the factory 30ยบ tilt for the panel for more space between pilot/passenger. This is a safety issue as in a forward crash as there is more room before the panel stops your face from its forward motion as opposed to a vertical panel that moves it closer to the occupants.
2) Maximize side width i.e. some builders install a "tilt back canopy" but that requires the supporting arms to come down on each side next to the pilot and passenger and takes up space.
3) Single center stick. This leaves the option of flying left or center seat. Another bonus (known only to experienced Sonex pilots) is that the center stick/left seat position prevents the stall warning device known as "the control stick triangle meets Mr. Johnson when using full back stick." Single center stick leaves a lot more room in the cockpit and makes entry and egress easier.
4) Not putting sub panels under the main panel that blocks legroom. Others have also extended the entire panel lower but again that takes up leg room and cramps the cockpit.
5) Trying to prevent placing items on the glareshield. Doing so blocks vision and gives the cockpit a smaller appearance.
6) Placing all the controls on the left. Makes flying safer (no "hand dance" with the controls) and gives much more room than center mounted controls.
7) Using the plans side mounted trim lever instead of a big red "Dial-A-Trim" knob sticking out of the panel.
8) Using the factory canopy. Todd's Canopies makes a canopy that is a bit taller but the sides are not as roomy and it had a weird shape overall. The factory canopy mounted as high as possible to get a good line to match the turtle deck to cowling transition was my choice.
9) A single layer of cushion. It is adequate and if more is needed for a longer cross country flight it can be added.
10) Using a Clarity Aloft headset that gives me room to wear a full brim hat and keep the sun off my ears and neck!
I'm using the factory interior but with my ideas implemented it leaves as much room as possible, doesn't have a great weight penalty, and it's very easy to remove. Here's what I arrived at:
FWIW,
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
166.7 hours / Status - Flying
