by WaiexN143NM » Sat Dec 09, 2017 12:33 am
Hi all,
Was looking at the eaa chapter 555 website , Las Cruces NM. Alot of you helped building the wings at eaa oshkosh 2015. By the looks of the photos im sure they will make it to osh2018. Plane is on the gear, wings, tail , control surfaces on, aerovee mounted. Panel finished. Looks like canopy and cowl to finish. Waiex taildragger. Thanks to Sonex, EAA, and all of your help.
A new one week wonder has been announced for OSH 2018. A Vans RV-12iS.
Any ideas for sonex for something new? I've suggested a new moni2 :
Single place, taildragger, v tail, pegasus O-100 engine, highly prefab, all matched hole final size, plans, construction manuel, dvd build videos( like the home built help series) , low cost , using as many existing parts from current sonex designs avbl , folding wings. Tilt /tip back canopy. Vinyl wrap kits. Hyd toe brakes. Engine 60 hp, 3 gph. MS-3 carb. Litewight b&c starter and alt. Emags electronic ignition. Something to soar with, but also x-c. Cowling,let the cylinders hang out in the breeze......eyebrow baffles.....
Your thoughts????
