plastic on ailerons
plastic on ailerons
Postby dfcpac » Thu Sep 14, 2017 7:40 pm
I have a white plastic on both ailerons I can't peel it off. I tried heating it but it would just melt. what is the secret on getting this white plastic covering off??
thank you
dan carley
n127nx
dfcpac
Re: plastic on ailerons
Postby Bryan Cotton » Thu Sep 14, 2017 9:53 pm
I found the stuff to be a pain, but it does peel off. Trick is getting it started and then taking your time. I never heated mine.
Postby sonex892. » Fri Sep 15, 2017 12:12 am
dfcpac wrote:I have a white plastic on both ailerons I can't peel it off. I tried heating it but it would just melt. what is the secret on getting this white plastic covering off??
thank you
dan carley
n127nx
Hi Dan. If you are melting it you are applying way too much heat. You just need enough heat to soften it.
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby peter anson » Fri Sep 15, 2017 1:28 am
Hi Dan, I know this won't help you, but the real trick to removing it is to take it off a few years ago. It seems to harden with age, but as Steve says, gentle heating will soften it.
Postby kevinh » Fri Sep 15, 2017 11:46 am
And gentle heat can be as simple as just leaving it in the sun while you do your work (if the climate is right).
kevinh
Users browsing this forum: Google [Bot] and 3 guests
