Elevator Pushrod Lube
Postby Direct C51 » Sat Sep 09, 2017 9:17 pm
What is the general consensus on what to use on the elevator pushrod where it passes through the plastic bushings? I tried white lithium grease but didn't like it very much.
Direct C51
Re: Elevator Pushrod Lube
Postby builderflyer » Sun Sep 10, 2017 8:50 am
I use Ivory bar soap as a lube here. Put it on wet as though I was washing my hands with it and seems to reduce the stickiness of the push tube for maybe a year or so. Other lubes I tried just didn't last very long. Oh, and when I built my Sonex I mounted the plastic guides on a standoff so that the push tube would be going through the guide at close to 90 degrees rather than at an angle if you mount them flat on the u-channel.
Hope this helps,
Art,,,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95
builderflyer
Postby Rynoth » Thu Sep 21, 2017 6:19 pm
I use LPS-2 for all my control connections. It's a long-lasting wet lubricant widely used in the aviation industry.
http://www.aircraftspruce.com/catalog/c ... ckkey=5211
LPS-1 is also an excellent dry lubricant that might work for you.
Users browsing this forum: No registered users and 52 guests
